So I've been reading a ton and learning from all the experts out here, and have a rough idea and some good measurements on what I need to set up. First - I have a spare PC that can run Blue Iris (and a handful of hard drives 2TB or bigger) - so I figured that would be a better direction than an NVR. But when it comes to cameras, I understand the technology, but am in a bit of analysis paralysis when it comes to nailing down what I may need.
My house is on a pretty standard lot for where we are. 80'x120'. The front corner of the garage is 35' from the bottom of the driveway, the front door is around the corner of the 3-car garage and set back another 20'. My plan was a camera on the corner of the garage, and one near/above the main entry. Then probably one for the side garage door, and one for the back of the house. That's my starter plan...can always add later but no need to overkill things.
Dahua seems to be a big favorite around here, I've been reading up on Hikvision as well as Reolink (no ONVIF for 4K), Amcrest, and a few others. For some reason I would prefer black cameras as I feel they would blend better - but my choices appear limited there. Past that, if I go Dahua everyone references Andy here on the forums...which is fine. Just need some general thoughts/opinions on whether I am on the right track with my thinking.
