My thermal just started detecting squirrels.
View attachment trim.41F539B9-C19B-4FBB-A782-9B522509BD7B.MOV
Awesome... and will the IPC-B54IR-ZE-S3 (bullet model) work as well?The latest versions of the Empire tech (Dahua) T54IR-ZE-S3 (varifocal), or the T54IR-AS S3 (fixed focal), combined with the latest firmware, do an excellent job of alerting on animals using the internal IVS triggers. Combine that with Blue Iris (onvif) and it works very well. Mine reliable alert on people, cars, deer, opossum, fox, and depending on minimum size settings, cats, squirrels, groundhogs, and skunks...all of which have dropped by recently. You would need to be able to run ethernet (POE) or have power if recording to an SD card only.
YesAwesome... and will the IPC-B54IR-ZE-S3 (bullet model) work as well?
Sorry I know this is an old post now, but wow really? I've been waiting for this for years!The latest versions of the Empire tech (Dahua) T54IR-ZE-S3 (varifocal), or the T54IR-AS S3 (fixed focal), combined with the latest firmware, do an excellent job of alerting on animals using the internal IVS triggers. Combine that with Blue Iris (onvif) and it works very well. Mine reliable alert on people, cars, deer, opossum, fox, and depending on minimum size settings, cats, squirrels, groundhogs, and skunks...all of which have dropped by recently. You would need to be able to run ethernet (POE) or have power if recording to an SD card only.
In the latest webUI, combined with the S3 Dahua (or Andy Cams), you do indeed see "animals" as a choice.Sorry I know this is an old post now, but wow really? I've been waiting for this for years!
So in their WebUI, you can actually select 'animal', next to 'humans' and 'motor vehicles'?
When it detects, does it actually detect the specific animal? ie. Dog, cat, rabbit, etc? Or does it just tag as 'animal'?
Any chance you could take a screenshot of the relevant webUI config page?
Here are the specific animals...Sorry I know this is an old post now, but wow really? I've been waiting for this for years!
I Think that option to choose "which" animals is available on the Pro Cameras (like on my T5459-Pro) firmware, but not on the latest (R8) version of the T54IR-S3 cameras. At least that's what I see on my versions.What FW/Camera is that? I dont update often...
