Hello and thank you all for providing such a wealth of knowledge to the world! It's good to find a source of technical info that's not masked by marketing, obfuscation and propaganda. I've been scouring the interwebs for accurate and helpful info on ip cameras and finally stumbled into this little world!
I have a manufacturing plant located in a small Missouri town. I want to monitor the property's exterior and have a smallish budget to get it done ($500-$600). So I've done what many do, went to Amazon, searched and got lost. After a couple of weeks I pulled the trigger and bought a small setup. I've uploaded a Google Earth image of the property layout with camera coverage indicated.
(2) Lorex 4MP 2K IP Dome LND4750ABW
(1) Lorex 4MP HD IP Bullet Camera with Color Night Vision LNB4421B
Monoprice 1000FT 24AWG Cat5e 350MHz UTP Solid, Riser Rated (CMR), Bulk Ethernet Bare Copper Cable
LINKOMM (20 Pack) 8P8C Cat5e Connector Pass Through Ethernet Modular Plug, Transparent
IPCamPower 8-Port POE Network Switch w/ 2 Add'l Uplink Ports POE+ - 30 Watts/Port - 130 Watt Total
Blue Iris Software 4.8.3.0 (Windows)
Blue Iris App (Android)
Dedicated computer for Blue Iris:
Windows 7 Pro
Intel Core i7-4770CPU @ 3.40GHz
8 GB RAM
Currently 1TB HD - may upgrade to a Seagate Skyhawk or WD Purple 4TB
After reading several threads here, it looks like I may have made a mistake with the Lorex camera. The specs looked good, what can I say. I don't have the budget right now for a >$750 system. I'm at $500 right now (already own the computer) and I think I have enough to get started. I'm looking for input on whether this will be a decent setup or if I should send back the cameras and start again. The 2 Dome cameras I chose for FOV (120) and the turret was cheap and shared the same specs (except FOV is only 90).
Dahua seems to be the preferred brand and I've read here that some Lorex models are just rebranded Dahuas. Can anyone comment on that?
I'm new to Blue Iris and networking/switches/ports. Any knowledge relating specifically to the camera models above it would be greatly appreciated! If you made it this far you've got a lot of time on your hands! Thanks again! Pete
Windows 7 Pro
8 GB RAM
