Deepstack Timeout
flyboy68
Mar 24, 2019
76
8
Kansas
For over a week i'm not getting any alerts from any of my cameras. All are using Deepstack. Nothing changed (that i know of) has worked for months but now deepstack timesout before detecting anything. Turn deepstack off and i get alerts but with it on it timesout. Any ideas?
Josh
Turn off use mainstream for starters.
Those are all at the timeout threshold - it could be the season change and more leaves are flying around and triggering more cameras than in the past.
And then open up the .DAT file you are saving and see what is going on.
They are in the Alerts folder or you can go to the BI status page and open up the Deepstack tab and then minimize it. Next go to an alert that didn't detect/timeout and start playing and then pause it and then open the minimized tab and it will show the details.
Reactions: looney2ns
Go to the folder to see the cancelled alerts? Or do timed out not show there?
The "also BVR" is for the GPU.
It is under the Record tab and then video file format that shows if you are BVR, which you should be if you are direct to disc.
But your error lends to believe you have gone in and changed something.
Tried that a few times. Is there a way to restart Deepstack? Is it possible Deepstack is taxing my CPU causing it to take too long? How could I see what the CPU is doing while deepstack is analyzing other than looking live and watching the CPU?
