Deepstack - "Nothing found"
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
No matter what settings I use on existing or new cameras, Deepstack is not finding anything. Any ideas on what might be happening? Thanks!
What cameras? Do your iframes match FPS, etc.
Post the BI camera status page showing FPS/KEY and bitrates for starters.
Interesting, that looks correct from the camera side.
How many images one second apart do you have BI sending to Deepstack. With AI tools I think it would send more than the default in BI. If yours says 1, try upping that.
I have it set to 6 images every second.
Have you tried the ole reboot the computer trick? I recall some saying that got it going.
Do you have the "burn" box checked to see if it is identifying anything at all other than what is in the log file?
I finally found what I believe to be the solution for me. Previously, I had Deepstack running all the time on my BI computer. Because of that, I did not have the option selected for BI to auto start/stop Deepstack. After turning this option on, by selecting it in settings, it seems to be working as expected.
