When would a user run more than one model?
What are the advantages to run "Combined, and "Dark" together? Disadvantage?
Do the extra model files need to be manually updated on occasion?
When a user enters the string, "Objects:0" then the Deepstack models are ignored, is that a good thing?
Does it help to enter "Banana" or "Zebra" in the To Cancel position?
When would you elect to use the "Begin Analysis with motion leading image"?
Do most users select "Use Mainstream if available? Does that feature depend on the speed of the console that's running BI?
Thanks in advance, I've read numerous posts hoping to get answers to the above, but I'm hoping for more clarification...
