That image does have the door partially blocking the logo. So it's not the best image to test with... again I think for this camera you may want to work on the triggering so you get an image before the deliverman opens the door on his vehicle. That said, your fedex image shows it's working. I am guessing if you use an image of a USPS van without the logo blocked by the door, it will confirm that as well.by the way not sure if this helps when I run the picture thru the codeproject, it can not find anything
Sorry almost missed this one from the previous page. That is pretty weird. I noticed CPAI sometimes can take a few minutes to settle down when certain changes are made. Have you given it some time? Have you tried stopping/restarting AI to see if it changes anything? Maybe after restarting they will go away. TBH I forgot exactly how I turned all that stuff off (pretty sure it was the 3-button menus though), but for sure mine only has yolo in green.Not sure what I'm doing wrong, I disable them but they start again. My computer is hunted
You are right, I had to reboot the computer and I was able to disable every option other than yoyo. ThanksSorry almost missed this one from the previous page. That is pretty weird. I noticed CPAI sometimes can take a few minutes to settle down when certain changes are made. Have you given it some time? Have you tried stopping/restarting AI to see if it changes anything? Maybe after restarting they will go away. TBH I forgot exactly how I turned all that stuff off (pretty sure it was the 3-button menus though), but for sure mine only has yolo in green.
