Hi all,
I'm setting up a few cameras so we can watch CNC machines run in case we see, or hear an issue etc while programming in the other room.
I was thinking of using the IPC-T5442T-ZE as I've had excellent luck with them for outdoor use.
But I realized these machines are generally very well lit and a higher frame rate is preferred over the typical 15.
Is the IPC-T5442T-ZE my best bet in that price range, or should I be going in a different direction due to good lighting?
