Good Morning folks,
I know the norm is to dirll a large hold in the wall or to install the camera on a j-box and drill a large hole on the face of the box.
However, here is the situation. I want to install a camera in a location where I cannot do either of the two. The best I can do is in stall a small small J-box to make the Ethernet connection inside. I would like to use some soft of cable gland to run the cable form the camera into the box but the large female CAT5/6 connector doesn't allow this.
I was thinking of cutting the end of the pig tail and install a male RJ45 connector on it in efforts to minimize its size and be able to get the cable through a normal sized cable gland and just delete the power and any other accessories.
I would really like to source some 2 piece cable gland? or if anyone else has ideas I would like to heard them.
Thanks
Thanks
