Dead air and clips
jelf4352
Aug 11, 2023
147
50
los angeles
Hi,
I record 24/7 in 1 hr intervals as to not make the file sizes too large per advice from other forum members. I have AI running to identify/confirm alerts. When I enable “skip dead-air”, it finds alerts but if there are none then it will skip to the end of the 1 hour clip. Is there anyway to make it skip only to the next alert? I don’t need to see the end of all my clips.
also, when I select my clips on the ui3 browser it will skip to the alert in a clip but will continue to play the remaining time in the clip (so it can play for up to 1 hour due to the interval). Is there anyway to make the clips in ui3 only for portion of the clip where there is confirmed alert?
im not sure what im doing wrong but it seems like there should be an easy fix?
