Daisy Chain an NVR?
OICU2
BIT Beta Team
Jan 12, 2016
921
1,663
USofA
Anyone ever try and daisy chain a Hik NVR? Is it even possible? For example, you have an 8 channel and you maxed it out. You buy a 4 channel, remove one cam from your 8ch, plug the 4ch into your original 8 channel, will the original 8ch NVR see the second NVR as a "camera" with multiple channels?
