Hi to all!
I have XVR5108HS-I3 with connected 5 analog cameras and 2 IP cameras attached.
I wanted to import analog cameras into Home Assistant, so I installed HACS and Dahua integration.
I have successfully added IP cameras into HA by calling their IP addresses, but when I enter the IP address of the XVR, I can't see any analog cameras streams.
For example, if I try to activate motion detection, I get an error:
Failed to perform the action switch/turn_on. 500, message='Internal Server Error', url='https://192.168.0.13/cgi-bin/configManager.cgi?action=setConfig&MotionDetect%5B1%5D.Enable=true&MotionDetect%5B1%5D.DetectVersion=V3.0'
Also, I tried to open analog cameras via VLC using RTSP, but also without success, getting error message:
Your input can't be opened:
VLC is unable to open the MRL 'rtsp:/admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0'. Check the log for details.
with log details:
live555 error: Failed to connect with rtsp:/192.168.0.13:554/cam/realmonitor?channel=1&subtype=0
satip error: read error: No error
satip error: Failed to setup RTSP session
main error: read error: No error
Does anyone have some tips what could i try?
Thank you everyone in advance...
with log details:
