Does anyone know the name of, or where I can buy the special wrench needed to tighten and lock the dahua cameras into place? Different models might have different wrenches, but does anyone know the name of the style/genre so that I can order a set on amazon or something? It doesn't look like a standard tension wrench
+1^^.
"Just received a Dahua IPC -T5442TM-AS Saturday from Andy and the included tool is same as my standard Torx T10 driver; the tool has a hole that a pin in the screw head would fit as many anti-tamper screws are, but your T10 will not need the hole, as the cam's screw did NOT have pin in it (at least mine didn't and I haven't seen a cam yet that did require the hole in the end of the bit).
