I have a problem that suddenly there is no notification in my iPhone when someone calls the VTO2211g-WP. I had firmware .511. Then I found the .700 firmware. On some sites it is for the "S" version, but on one dahua site it says that it is the same for mine. Notifications are still not working. I went back to the .511 and did the SCM as well. The notifications worked, but now I can't add the ONVIF user to VTO. The operation failed. I update again to .700 then ONVIF works but notifications do not work! It is very inconvenient to restore to factory settings, because it is not connected by a cable, only wifi and it is inconvenient to take it off and unsolder it to bring it to the house for configuration.. I use p2p.
