| ARC5402A-W | |
| Name | Video Alarm Control Panel |
| System | |
| Main Processor | High-performance industrial embedded microcontroller |
| Operating System | Embedded LINUX |
| In and Out | |
| Wired Zones | 2 on-board zones |
| Wireless Zones | 28 wireless detectors, 2-way communication, transmission range up to 150m open space |
| Alarm Output | 1-ch relay output |
| Tamper Funtion | 1 tamper switch |
| Wireless keyfob | 8 wireless keyfobs |
| Siren | 4 wireless sirens + 1 wired siren |
| Storage | Max 128GB micro SD card for video recording, USB device to backup video |
| ID Card | RFID reader(arm/disarm) |
| Network | |
| Network Function | TCP/IP, DHCP, WIFI, P2P, IP Search(Support IP camera), DMSS |
| Interface | |
| Network Interface | 1 RJ-45 Port(10/100Mbps) |
| RS485 | 1 Port |
| PSTN | 2 groups PSTN, support Contact ID standard protocol alarm |
| Wired Siren | 1 wired siren(12V/0.5A) |
| Auxiliary Power Output | 1 auxiliary power output(12V/0.5A) |
| Reset | Insert two ends of cable into the holes to reset |
| USB | 1 USB 2.0 port to record or upgrade |
| Audio and Video | |
| IP Camera Channel | 4 Channel |
| Compression | H.264 |
| Resolution | D1 |
| LCD Screen | 4.3 inch TFT screen, 480*272 resolution |
| Audio In | 1 ch audio in for 30s voice message |
| Audio Out | 1 ch audio out for voice and alarm broadcast |
| Upgrade | |
| Remote Upgrade | USB disk or ConfigTool to remotely upgrade |
| General Parameters | |
| Main Power | DC12V/2A |
| Backup Battery | 3.7V/1900mAh, Li-ion |
| Power Consumption | ≤5W |
| Operating Temperature | -10℃~ +55℃ |
| Humidity | 10% ~ 90% |
| Device Dimensions | 216*118*28mm |
| Device Weight | <1kg |
| Installation | Wall mounting |
| ARD1231-W | |
| Name | Wireless passive infrared sensor |
| Detection | Passive infrared |
| Detection Range | 12m×12m, 90° |
| Alarm prompt | Red LED, can be set to switch off |
| Sensitivity | Two level (jumper) |
| Wireless Frequency | 433/868MHz |
| Transmit power | 10dBm |
| Transmit distance | 150m open area/no interference |
| Pet immunity | ≤18Kg |
| Resistance light | 6500LUX |
| Working environment | -10°C~+50°C, humidity <95° |
| Overall dimensions/weight | 105mmx62mmx41.3mm/0.1kg |
| Tamper | Unit protection and leaving-wall protection |
| Power | 1xCR123A battery |
| Installation height | Wall mount, 2.2-2.5m |
| ARD1611-W | |
| Name | Wireless Curtain PIR Detector |
| Detection Range | 10m/15° |
| Alarm prompt | Notification LED light, can be set to switch off |
| Sensitivity | Two level (jumper switch) |
| Transmit distance | 150m, open area/no interference |
| Overall dimensions/weight | 99mmx52mmx35mm/0.1kg |
| Installation height | Ceiling/Wall mount, 2.2-2.5m |
| ARD311-W | |
| Name | Wireless door sensor |
| Motion distance | 25-40mm |
| Transmit Power | 10dBm |
| Transmit Distance | 150m(open area/no interference) |
| Tamper | Front cover and rear cover protection |
| Installation Way | Screw and glue |
| Dimensions | 84*39*22mm |
| Weight | 0.1kg |
| Temperature | -10°C~50°C |
| Humidity | < 95% |
| Installation | Screw or glue to mount |
| ARD800-W | |
| Name | Panic Button |
| Trigger Alarm | Button pressed down |
| Alarm prompt | Alarm success: green LED on |
| Alarm failure: red LED on | |
| Transmit Distance | 150 meters(open area/no interference) |
| Indoor 30 meters, 1 wall capability | |
| Power | 1xCR2450 battery |
| Dimensions | 42*43.8*13mm |
| Weight | 0.05kg |
| Temperature | -10°C~55°C |
| Humidity | < 95% |
| Installation | Hang on the neck or 3M glue to mount |
| ARA22-W | |
| Name | Remote keyfob |
| Working Voltage | DC3.0V |
| Key | Away Arm/Stay Arm/Disarm/SOS |
| Ingress protection | IP20 |
| Dimension | 62*30*14mm |
