Hi,
I have 5 Dahua IPC-T5442TM-AS 2.8MM, purchased from Andy, which are superb, however I wanted to give full colour night vision a try so I have just installed a Hikvision DS-2CD2347G1-LU 2.8MM
I immediately notice that under exactly the same conditions (cam-garden and cam-rear2 in the same place facing the same direction) the bitrate of the Dahua is around 1000kB/s but the Hikvision is around double, 2000kB/s.
I "think" both are configured the same:
HikVision:
Dahua:
The "Max Bit Rate" of the Hikvision allows me to put a higher value (16384 as opposed to the Dahua at 8192), but both of those figures are way higher than is being sent so I doubt that would cause the bitrate to double)?
Does anyone know why the Hikvision, with the same settings, showing the same picture at the same quality/resolution etc (and the picture of both looks identical in quality to my eyes), would use double the bandwidth? Does Blue Iris treat these streams differently or something?
Thanks,
Tom.
HikVision:
Dahua:
Thanks,
Tom.
