Dahua SmartPSS Intercom "The current device is busy or offline"
zaqik
Jun 15, 2022
37
12
eet
Hi!
I use SmartPSS 2.02.2 since the Intercom feature disappeared from newer releases. I add my VTO to Devices, then I set up Intercom according to the manual page here: DahuaWiki
However, there's no "MGT Centre IP Address" option in my VTO's webui because it looks completely different like in this manual: DahuaWiki
So, whenever I try to begin a Video Talk in the way showed on the last screenshot in that manual (Start Shout menu item) I get a small error window in the lower right corner of my monitor saying "The current device is busy or offline"
There's zero information on the Internet, so this forum is my last hope.
Thank you very much! However, I could not see version 2.02.2 in there? Only version 2.02.1? There was a txt file mentioned regarding that version but not the actual file itself.
Thanks again
I found a version of 2.02.2 ENG/Chinese version but the intercom option is not there. I am hoping your version has an intercom version or perhaps your version is an international version? Thanks again
Intercom is absent since 2.02.08, so you need version below it. I use 2.02.1R, you can use 2.02.07 - both have their own bugs. However, my guess is older builds with intercom feature isn't fully compatible with newer hardware (says WEBSERVICE 2.0 in webUI).
Thank you again. I have tried versions after 2.02.1R but the intercom option is not present in the menu. I think Dahua have re-released versions with the intercom not in it anymore. As mentioned, I found a version 2.02.2 but no intercom option. If you have a working version of 2.02.07 with intercom I would love to obtain it off you.
Thanks again
