Dahua Smart PSS not finding network host? NVR4104-P
jRiffRaff
Sep 10, 2017
6
Hi,
I have a DAHUA NVR4104-P NVR connected to 2 DAHUA IPC-HFW4421B cameras. I used to be able to view the camera feed from Smart PSS on my networked computers (and directly from the web app if I ran the old browsers).
Recently I upgraded my cable internet to a higher speed and with it got a new cable modem. I run the modem in bridge mode connected to my router and I haven't changed any settings on my router (I assigned a fixed/reserved IP address to the NVR).
Coincidentally (or not) I can't view the camera feed anymore. I can ping the NVR and get a response, but Smart PSS reports the NVR as being offline "Can not find network host". When I look at the DHCP list on my router, the NVR also doesn't show up. So how is it responding to a ping?
Since I didn't make any changes on 'this side' of the network I am at a loss what to do to make things work again.
Any ideas?
Thanks,
jRiff
just plug the nvr out and ping again. if you get an answer somebody/something is using the nvr ip.
and when you give the nvr a fixed address then it will not show up in the dhcp list
I disconnected the NVR and it did not respond to the ping. Also, my other devices with reserved IP addresses do show up on the DHCP list. I also checked the ARP table and the MAC address associated with the IP address in question matches my NVR.
jRiff
I just realized that when I upgraded my modem, I also upgraded the firmware of my Linksys EA8500 router. Could that be causing problems?
Thanks,
jRiff
Still lost...Now I'm wondering if there is something in the NVR itself that I may have disabled to prevent remote connections. Is that possible?
jRiff
Okay, so I realize I'm just talking to myself here, but for the record:
I've now discovered that if I configure my device under the IP of my NVR on my local network, I have the issues - HOWEVER if I configure the device to use the domain of my dynamic DNS forwarding service which redirects to the NVR through my router, IT WORKS!
So now I don't understand what is different between the 2.
Anyone, Anyone, Bueller? Bueller?
If anyone comes here looking for solution for similar issue first and foremost do check what method you used to add the NVR to the smartpss software. If you added through a direct IP or through search feature then simply remove the NVR and again add the NVR through Serial Number and make sure P2P is enabled in NVR Network settings. Thats one way to solve this issue.
Reactions: chrisd015
I had this problem simply after rebooting a Win 7 PC that had been working for months without an issue. No network changes. Anyway, this approach of remove and re-add device using the Serial Number worked a treat. Thank you.
