Dahua smallest outdoor PTZ ?
Thanks aristobrat
I saw another that was a smaller dome, I was hoping for one with no dome.
Do you own this one and if so do you have glare problems ?
I do own one although I'm in the process of relocating it at the moment.
The way it was placed, the IR would for sure bounce back off of a wall 20 feet in front of it and ghost out the image.
Here's what it looked like with IR on:
ir-jpg.28261
Here's what it looked like with the IR off... I had enough ambient light coming in from the street for it to work well.
2mp-starlight-jpg.28260
I'm in the process of moving it over by the garage, where it will look away from the house (down the center of the driveway).v I don't except to get much IR bounce-back from that, so I'll try running with IR again and post back with how it goes... It'll be a bit before I can get to that, though.
If you haven't had a chance, check out the review thread in my last post... There are some other pictures/videos from @looney2ns and others...
Thanks aristobrat
Hi @Baldcamman
When I started I was also looking for an outdoor PTZ which would be a smaller 4-5" diameter w/o a dome.
From what I have seen: due to the need for IP66+ ratings the outdoor rated PTZ cameras are either smaller w/a dome or larger w/o a dome.
I ended up going with 2 turret cameras instead
Thanks you guys
Yea I know I want a PTZ just don't have a high spot on the house to hang it, it would look like this :)
