Dahua slow releases of firmware?
ProsjektX
Jan 27, 2018
2
Considering to buy a NVR4208-8P-4KS2, but at least from the Dahua site it seems all NVR firmware, for different models, are in the range of 1 to 2 years old. I'm a bit concerned about what seems to be a very slow release cycle, so probably they will have lots of security issues in different components.
What are peoples thoughts around this? Also, which Linux kernel are they running currently?
Rule one on cameras and NVRs . Do not upgrade unless it is fixes a known problem you are having.
If you upgrade just because.... it will turn into a brick... search the forum and look at all the problems people are having after upgrading. The NVR is an appliance... do you upgrade your television ? do you upgrade your car ? do you upgrade your refrigerator ?
Most of the Chinese camera companies have no use in providing support to end users. You MUST purchase from a quality supplier. That supplier should provide support.
Security is not not the responsibility of the NVR or cameras. It is the responsibility of the network management and its configuration.
