- Feb 15, 2017
- 1,502
- 1,159
Ok guys,
I bought the Dahua SD1A203T-GN-W off of @EMPIRETECANDY
I know there will be alot of WIFI camera nasayers..
I have to be honest this camera is pretty awesome.. I had some difficulty connecting wirelessly at first but only because I didn't understand which router security setting was most compatible with this wifi model. I'll explain which setting to use..
So you need to set your router to:
Wpa2-psk-aes
I'm still adding footage and will continue to do so, keep checking back for updates.
So here is my take on the Camera:
•Resolution is outstanding
•Pan and Tilt speed is adjustable
•Zoom is surprisingly good when digital zoom is activated
•Microphone is really strong, have it turned down to about 40% and it's still loud
•Durability is great, metal base, well built.. Temp was 25° last night and no issues.. I know thats not that cold but best I can test right now.
•Mount was easy to install
STAY TUNED FOR MORE VIDEO FOOTAGE AND PICTURES THIS WEEKEND
*Added some pictures of the actual camera and its mounting.. It's temporarily mounted in an old bookshelf only about 2.5 ft off the ground for testing purposes.
Andy is awesome for those that don't know. Great customer service and support
Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group to Clipboard
(from AliExpress Android)
https://www.amazon.com/s?marketplac...3EBQGJF&merchant=A329YQ83EBQGJF&redirect=true
1/2.8” STARVIS™ CMOS
Effective Pixels
1920(H) x 1080(V), 2 Megapixels
RAM/ROM
512M/128M
Scanning System
Progressive
Electronic Shutter Speed
1/1s~1/30,000s
Minimum Illumination
Color: [email protected]; [email protected] (IR on)
S/N Ratio
More than 50dB
IR Distance
Distance up to 15m (49.2ft)
IR On/Off Control
Auto/Manual
IR LEDs
3
Lens
Focal Length
2.7mm~8.1mm
Max. Aperture
F1.8
Angle of View
H: 105.6° ~ 35.2°
Optical Zoom
3x
Focus Control
Auto/Manual
Close Focus Distance
100mm~ 1000mm
DORI Distance
Note: The DORI distance is a “general proximity” of distance which makes it easy to pinpoint the right camera for your needs. The DORI distance is calculated based on sensor specification and lab test result according to EN 62676-4 which defines the criteria for Detect, Observe, Recognize and Identify respectively.
Detect
Observe
Recognize
Identify
100.4m(329.4)
40.2m(131.9ft)
20.1m(65.9ft)
10m(32.8ft)
PTZ
Pan/Tilt Range
Pan: 0° ~ 355°; Tilt: 5° ~ 90°
Manual Control Speed
Pan: 0.1° ~70° /s; Tilt: 0.1° ~30° /s
Preset Speed
Pan: 80° /s; Tilt: 40° /s
Presets
300
PTZ Mode
8 Tour
Speed Setup
Human-oriented focal Length/speed adaptation
Power up Action
Auto restore to previous PTZ and lens status after power failure
Idle Motion
Activate Preset/Tour if there is no command in the specified period
Protocol
DH-SD
Intelligence
Auto Tracking
N/A
IVS
Tripwire, Intrusion,Abandoned/Missing, Face Detection
Video
Compression
H.265+/H.265/H.264+/H.264
Streaming Capability
3 Streams
Resolution
1080P(1920×1080)/720P(1280×720)/D1(704×576/704×480)/CIF(352×288/352×240)
Frame Rate
Main stream: 1080P/720P(1 ~ 25/30fps)
Sub stream1: D1/CIF(1 ~ 25/30fps)
Sub stream2: 720P/D1/CIF(1 ~ 25/30fps)
Bit Rate Control
CBR/VBR
Bit Rate
H.265/H.264: 448K ~ 8192Kbps
Day/Night
Auto(ICR) / Color / B/W
Backlight Compensation
BLC / HLC / WDR(120dB)
White Balance
Auto,ATW,Indoor,Outdoor,Manual
Gain Control
Auto / Manual
Noise Reduction
Ultra DNR (2D/3D)
Motion Detection
Support
Region of Interest
Support
Electronic Image Stabilization (EIS)
N/A
Defog
Support
Digital Zoom
16x
Flip
180°
Privacy Masking
Up to 24 areas
Audio
Compression
G.711a/G.711mu/G.726/AAC
Network
Ethernet
RJ-45 (10Base-T/100Base-TX)
Wi-Fi
Wi-Fi(IEEE802.11a/b/g/n/ac) , Dual-Band Wi-Fi
Protocol
IPv4/IPv6,HTTP,HTTPS,SSL,TCP/IP, UDP,UPnP,ICMP,IGMP,SNMP,RTSP,RTP, SMTP, NTP,DHCP, DNS,PPPOE,DDNS,FTP, IP Filter,QoS,Bonjour,802.1x
Interoperability
ONVIF, PSIA, CGI
Streaming Method
Unicast / Multicast
Max. User Access
20 users
Edge Storage
NAS (Network Attached Storage),Local PC for instant recording, Micro SD card 256GB
Web Viewer
IE, Chrome, Firefox, Safari
Management Software
Smart PSS, DSS
Smart Phone
IOS, Android
Certifications
Certifications
CE: EN55032/EN55024/EN50130-4
FCC: Part15 subpartB,ANSI C63.4- 2014
UL: UL60950-1+CAN/CSA C22.2,No.60950-1
Interface
Video Interface
N/A
RS485
N/A
Audio I/O
Mic in/Line in, Line out
Alarm I/O
N/A
Electrical
Power Supply
DC 12V/1.5A
Power Consumption
7.8W, 10.5W (IR on)
Environmental
Operating Conditions
-30°C ~ 60°C (-22°F ~ +140°F) / Less than 95% RH
Ingress Protection
IP66
Vandal Resistance
IK08
Construction
Casing
Metal
Dimensions
Φ128(mm) x 63(mm)
Net Weight
0.49kg(1.08lb)
Gross Weight
0.73kg(1.6lb)
Subscribe to get the latest news & products information
Wpa2-psk-aes
Effective Pixels
RAM/ROM
512M/128M
Scanning System
Progressive
1/1s~1/30,000s
S/N Ratio
More than 50dB
IR Distance
IR On/Off Control
Auto/Manual
IR LEDs
3
Lens
Focal Length
2.7mm~8.1mm
Max. Aperture
F1.8
Angle of View
H: 105.6° ~ 35.2°
Optical Zoom
3x
Focus Control
Auto/Manual
100mm~ 1000mm
DORI Distance
Detect
Observe
Recognize
Identify
100.4m(329.4)
40.2m(131.9ft)
20.1m(65.9ft)
10m(32.8ft)
PTZ
Pan/Tilt Range
Preset Speed
Presets
300
PTZ Mode
8 Tour
Speed Setup
Power up Action
Idle Motion
Protocol
DH-SD
Intelligence
Auto Tracking
N/A
IVS
Video
Compression
3 Streams
Resolution
Frame Rate
Bit Rate Control
CBR/VBR
Bit Rate
Day/Night
White Balance
Gain Control
Auto / Manual
Noise Reduction
Ultra DNR (2D/3D)
Motion Detection
Support
Region of Interest
Support
N/A
Defog
Support
Digital Zoom
16x
Flip
180°
Privacy Masking
Up to 24 areas
Audio
Compression
Network
Ethernet
Wi-Fi
Protocol
Interoperability
ONVIF, PSIA, CGI
Streaming Method
Unicast / Multicast
Max. User Access
20 users
Edge Storage
Web Viewer
Management Software
Smart PSS, DSS
Smart Phone
IOS, Android
Certifications
Certifications
Interface
Video Interface
N/A
RS485
N/A
Audio I/O
Alarm I/O
N/A
Electrical
Power Supply
DC 12V/1.5A
Power Consumption
7.8W, 10.5W (IR on)
Environmental
Ingress Protection
IP66
Vandal Resistance
IK08
Construction
Casing
Metal
Dimensions
Φ128(mm) x 63(mm)
Net Weight
0.49kg(1.08lb)
Gross Weight
0.73kg(1.6lb)
- New Products
- Lite Series
Positioning System
Anti-Corrosion
Explosion proof - Thermal Products
- Intelligent Building
- Intelligent Transportation
- Transmission
- Display & Control
- Machine Vision
- Video Conferencing
- Drone
- Software
- Accessories
- Others
- Discontinued Products
