I purchased three IPC-T5442T-ZE cameras from Andy in October 2022. I installed two of them in 2023 and they're working very well - no problems at all. I was trying to install the third one today, but I'm encountering issues while bench testing it. I haven't used that one before - it's brand new out of box.
The problem I'm having is that it's dropping the network link every 5-10 seconds. I can ping 192.168.1.108 once, but then it becomes inaccessible again until 5-10 seconds later. Here's a video of a PoE switch demonstrating the fault. The camera is plugged in to port 11:
You can see the link light turns off, then turns on again a bit later. I tried it with a different switch and a different network cable, too. Same issue.
I've tried resetting it using the 'reset' button next to the SD card slot, but that didn't help.
I've emailed Andy about it, but has anyone seen this before? Any ideas?
