Dahua reset experience.
Gimmons
Getting comfortable
Jan 7, 2022
315
461
California
I bricked a new Dahua IPC-HDBW5441F-AS-E2 trying to do a firmware update. The camera was visible on the router from my browser, but the login page was first garbled and then non-responsive.
Here's what I learned getting it back online:
1. Don't update firmware if you don't need to.
2. Use at least a 2 amp adapter when you do a hard reset. I was hitting the camera's reset button, first in situ, with POE over a long cable run, then on the bench with a 1.5 amp adapter. I was getting nowhere and started reading forum posts about various ways to reset and update firmware. Andy commented somewhere that you need at least a 2 amp adapter to do a hard reset. I changed the adapter out, hit reset and it worked.
3. Take your other cameras off the network when you reinitialize and install on your network. I knew the camera was ok again when plugged directly into my computer, but it became unreachable when I added it back on the network. Following the comments I read here, I disconnected the other cameras, released the static address reservation for the reset camera, and added it back to the network, then brought the other cameras on.
I actually learned a lot from this exercise, though I hope I won't have to go through it again. So if you're having trouble with a reset, make sure you power the camera with an adapter of at least 2 amps when you hit the reset button.
Everyone seems to think that the number one rule of IPCams is "IPCAMS multiple like rabbits". But that is really the number two rule.
The number one rule is "Don't update firmware if you don't need to".
