My older Qolsys IQ2 panel took a dump after 6 years, so I updated to an IQ4 last week. I've purchased a few door/window sensors (wireless for those unaware) that have terminals for external contacts and I've setup a few around the house to be "monitor only" (i.e. side gate opens triggering z-wave lights through IQ panel, no alarm). It dawned on me that few of my cameras have relay outputs. I found this thread by @bickford and it looks like Ajax had the same approach. I have a few new sensors coming and was wondering if someone can clarify a question? My first test is going to be using my IPC-B5442E-ZE coupled to an IVS tripwire. I can't confirm from the drawings, but is the relay out a dry contact? From my interpretation, it is. It appears the circuit is rated for 12V 300mA, or is the circuit powered? Here's the manual picture.
This got me super excited and if it works I'll be up all night scheming ideas and dumping cash on more z-wave hardware. Thanks in advance for any input.
According to step 2, for circuit scenario Mode B, the output is NOT a dry relay contact within the camera. But, the camera does not source any power. If you need a dry contact signal, you could insert a small icecube or reed relay being driven by the camera output, in the circuit. Typically, that is the safest way of controlling external devices. There would be no danger of the amperage load increasing on your milliamp output and would give you the option of being able to control several devices at once off of one relay.
