Hi There
I would like to know if anyone has installed and or used a Dahua Radar?
A few things i would like to know is, does it need to be right at a PTZ to work or can you put the radar in a different location and still set up the PTZ to go to the activation are, I.E. humans or vehicles? How does the wiring work, do you need to run a ethernet cable or a coms cable back to the xvr/nvr ?
Also, how good is the unit? Do you get many false alarms etc?
