This is a continuation of trying to add a dahua dome ptz camera to my Hikvision nvr. So far I have been unable to access the camera via the POE port so decided to try upgrading the firmware. I have downloaded two folders with contents below. The first folder has several .bin files which I assume are upgrade files? Just want to make sure I apply the correct update files. Do I apply all the .bin files and does order matter? Thanks.
