generalinq
Manually entering worked, I can see the cams. Wondering why the scan didn't, but not wondering long. Now to see if I can set up notifications then get the VPN going.. Thank you generalinq!!!!! All my cams IPs are set by the NVR at the 10.1.1..65-68 addresses, do I need to change them to my network 192.168.x.x address?
Nope no need to change them. From what I learned on this site, changing the internal IPs that the NVR assigns so that they are the within the same subnet as your LAN will not make a difference. I left mine as is using the 10.1.1.X. Changing them apparently will not allow you to access the cameras directly. You can plug an Ethernet cable into one of the available ports on your NVR and connect a PC/laptop to the other end to connect directly to the camera if needed. Or just use a PoE switch and plug everything into that.
