Hi,
I have recently purchased the Dahua PTZ model SDAL6245U-HNI-IR to replace my older Hikvision PTZ model DS-2DE7186-AE. I have it connected via ONVIF to my Hikvision NVR DS-7616NI-I2/16p.
The problem is that at night the Dahua SmartIR function doesn't dim the image down enough automatically when focussing on a vehicle number plate. This occurs after the PTZ has been in Colour Mode (day time) and it switches into Black & White mode (night time). I have to either...
1. Manually reboot the PTZ to get SmartIR to dim down sufficiently to see the car number plate.
2. Reselect the SmartIR from the IR Light section by selecting 'ZoomPrio' and then reselecting SmartIR.
By doing this the image immediately dims down sufficiently to clearly display the number plate details.
https://www.dropbox.com/s/qcr95c3kqtg0yqk/Dahua%20SmartIR%20Problem.mp4?dl=0
Essentially I have to manually switch the PTZ IR Light mode from SmartIR to ZoomPrio and then back to SmartIR (or reboot the PTZ) in order to get the PTZ to dim sufficiently to view car number plates at night time, after the PTZ switches from day time mode to night mode
I have tried numerous firmware versions and also liaised with technical reps from Dahua. The Dahua reps are not able to explain why I need to reselect the SmartIR option to make this perform properly (for want of a better word). To me it looks like a firmware problem in that after being in Colour Mode (day time) the functionality that governs the SmartIR function doesn't work properly when in Black & White mode (night time). My older Hikvision PTZ had no problems with this scenario (maybe I shouldn't be comparing my old Hikvision DE Series PTZ to this new Dahua Ultra Series model??? Although I would have thought that the Ultra Series Dahua would be somewhat of a step up from the Hikvision DE Series????).
I would greatly appreciate any suggestions. Thanks in advance…
Best Regards!
Best Regards!
