lsonee Young grasshopper Jul 12, 2021 46 10 May 15, 2023 #1 I have a 2019 Dahua PTZ camera, and if i attempt to use the controls in blue iris to move it to the right, it just keeps spinning around and around. Anyone have a similar issue? Reactions: mat200
biggen Known around here May 6, 2018 2,931 3,370 May 15, 2023 #2 It sounds like BI is probably sending it the wrong control commands. Did this just happen or has it always done this?
lsonee Young grasshopper Jul 12, 2021 46 10 May 15, 2023 #3 biggen said: It sounds like BI is probably sending it the wrong control commands. Did this just happen or has it always done this? Click to expand... always done this
biggen Known around here May 6, 2018 2,931 3,370 May 15, 2023 #4 I assume you did the "Find/Inspect" thing when you added the camera? In the PTZ/Control tab of BI, did you try the other Dahua presets?
looney2ns IPCT Contributor Sep 25, 2016 16,845 25,134 Evansville, In. USA May 15, 2023 #5 Be sure you are using the Dahua V4 New from the drop down in the PTZ BI setup page, instead of ONVIF, Reactions: International784 and mat200
lsonee Young grasshopper Jul 12, 2021 46 10 May 16, 2023 #6 looney2ns said: Be sure you are using the Dahua V4 New from the drop down in the PTZ BI setup page, instead of ONVIF, Click to expand... Thanks i will give this a try. Reactions: looney2ns
I International784 Getting the hang of it Apr 7, 2023 305 98 USA May 18, 2023 #7 looney2ns said: Be sure you are using the Dahua V4 New from the drop down in the PTZ BI setup page, instead of ONVIF, Click to expand... This works. Reactions: CanCuba
