I am looking for a simple low cost solution to connect a Dahua NVR w/ POE ports to one or two cameras located a couple of hundred feet away. I was using an abandoned coax with ethernet over coax adapters and it worked for a long time. But it became intermittent and since no longer works over the coax. I want to use a wireless bridge to get the cameras back online. And before anyone ask, I have verified the camera to work when plugged directly into the NVR.
I am not familiar with networking but assuming that if I use a point to point wireless bridge, that I could plug in the master to one of the POE ports on the NVR and at the remote end could plug into the bridge and operate one camera? I need for the remote end to support POE to the camera. If not, does that mean I would need to add a POE injector?
And what if I wanted to view multiple cameras over the bridge? I don't know what my NVR is capable of, it's probably pretty old, but would I have to add a POE switch to each end of the bridge?
I am probably OK with connecting to just one camera depending on how complicated (and stressful) it would be for me to connect to more than one.
So if just one camera, what recommendations do any of you have to connect one port on the NVR to master bridge and one camera to the remote using POE for the camera? I have power available for the bridges themselves.
And if I want multiple cameras, will I need POE switches on both ends or does that depend on the capability of my NVR?
Alternately, I do have WIFI at the gate now but it's on a separate network. I don't know if there is a way for my NVR to make use of the separate WIFI network that would not be too complicated?
Thanks
Thanks
