I'm seeing a relatively high failure rate (7 out of 32 cameras, so far) at a specific site installed in late 2019. Most (but not all!) of the cameras are on LR1002-1ET transmitters (Single-Port Long Reach Ethernet over Coax Extender) coupled with LR1002 (EoC Passive Converter).
In both configurations the dead component is the 802.3af -> 12v downconverter module inside the camera.
Is this common? Are replacement modules available? So far I've just been dropping in the PoE -> 12v converters but they're a bit of an eye sore in some spots and I shouldn't have to do it in the first place.
- Indoor, climate controlled, no burn marks, no water nearby.
- The dead cameras were powered by two separate Cisco switches on UPS, in different parts of the building.
- I've seen the same problem at different sites, though not nearly so often.
