This camera does not use PoE power, its power supply is external and you would have to incorporate an additional power adapter for the microphone.For external mic, @looney2ns provided a great link. It's a long thread, but lotsa info, esp on how to use a poe splitter to provide power for a mic.
Regarding the connections, bare wire (without connectors) is actually nice in some installations. If using a mounting box of some kind, where space is really limited, connectors take up a lot of space. The poe splitter needs room, so not having bulky audio connectors has benefits.
The ipcamtalk wiki has an informative section on ways to hook up mics.
This is another great source: How-To: Audio Inputs
Lots of info from legendary nayr...
Fastb
I understand that you could always send power through PoE, but it is probably not good for the camera to have power coming in through PoE and at the same time with the power adapter. Unless there is some sort of ethernet adapter so that when the power comes in, you can plug the camera in and not have power coming in through PoE and you can split it up to power a microphone. I'm going to have a look at that Wiki-IPcamtalk link. Thank you very much.
