Hi
I purchased Laview pack with 6 poe cameras. I need to add additional Turret style cameras. Which brand should I buy Duhua and Hikvision? I don't need 4mp or 2 or 3mp should be fine. Laview is ONVIF compatible, I need to know which works better? Any recommendations. I checked the local CCTV store he has two type one is HIKVISION and other one OEM HIKVISION, he mentioned both works same and quality wise but price difference is quite high over $100 between OEM and HIKVISION.
I searched Dauha one they are cheaper than HIKVISION, just wondering If I should go with Dahua with type or NVR
Thanks
LaView LV-KN988P86A4 Premium IP Surveillance System 8 Channel NVR + 6 x Full HD 1080P Day/Night In/Outdoor Cameras (No HDD Included)-Newegg.com
Thanks
