I took a gamble and updated firmware on my NVR-5232-4KS2.
I am now running V4.002.0000000.6.R (2022-11-15)
Unfortunately, the problem that it will not name my non-Dahua cameras correctly still exists
The cameras are called IPC and I cannot change it.
I tried the following:
Any workarounds?
Maybe I can change them some other way using SSH or another "trick"?
(The seller of the NVR does not respond to my emails. Very disappointed with that. I expected more from them)
Have any of you also got this problem? Please let me know so we can keep in contact in case the problem will get solved in the (far) future.
I am open to suggestions.
Kind regards,
Demesmaeker
- Changing the name using smartPSS
- Changing the name on the NVR itself (conntected to a screen, with a mouse)
- Changing the name using the webserver on my NVR
- Changing the name on the camera itself with and without plugin
- Changing the name on the camera itself with and without plugin on Internet Explorer and the plugin from the camera active
- Restoring my NVR to the factory default and retry it all.
Any workarounds?
Kind regards,
Demesmaeker
