P Pmedicj Getting the hang of it Apr 8, 2018 112 48 Jul 1, 2018 #1 my NVR seems to be working correctly by I have a blue status light and a power light on. Power is ok but Manual says a blue status light = malfunction.
looney2ns IPCT Contributor Sep 25, 2016 16,377 24,305 Evansville, In. USA Jul 4, 2018 #2 Pmedicj said: my NVR seems to be working correctly by I have a blue status light and a power light on. Power is ok but Manual says a blue status light = malfunction. Click to expand... Look in the NVR's log area to see what it is. Reactions: MixManSC and mat200
P Pmedicj Getting the hang of it Apr 8, 2018 112 48 Jul 4, 2018 #3 I have no errors in the log, rebooted system, formatted hard drives and checked smart details no errors and checked log again. Everything seems good. Somethings up with the status light, it wasn’t there before. Any other ideas what to Check?
J jeroenvtec n3wb Sep 26, 2020 5 0 Netherlands Sep 26, 2020 #4 I have the same did you find a answer regarding the light ? I only have single disk, and as far I can see all is green
