I have a problem with NVR1B08HS log file. I had a NVR1B04 before and moved to 8 channel system. The only difference between both models is number of supported cams.
New system does not record events e.g. IPC offline alarm, system settings changes, log in address… except reboot and clear command are recorded.
Missing events are marked as »Log« in their settings, so they should appear in event log. Time is also set up to GMT+1, synchornization with NTP server, DST enabled. I had the same settings in 4 channel system before which worked.
Does anyone has any idea?
