Dahua NVR with easy4ip and non dahua camera..
rufunky
Pulling my weight
Dec 2, 2015
707
248
I currently have my work NVR configured to 3 ACTI cameras setup through onvif with easy4ip enabled on the NVR. When I go to view the cameras on my phone through the easy4ip app the cameras come up fine but under the video where it is supposed to show a timeline to watch previously recorded video it instead says " no record".
so basically, all I get is a live stream.
Seeing the NVR is setup for the easy4ip then it should not matter what brand cameras as long as they are setup and functioning locally correct??
EDIT!!!
OK with anyone having this issue be sure you have a camera set to the first slots( D1 ) as it defaults to loading this slot regardless if there is a camera assigned to it or not. Thus giving an error "no record". Once I navigate to the appropriate slot and highlight the video, the timeline for that video does indeed show.
