Dahua NVR Recording Space
HMC8403
Getting comfortable
Jul 10, 2020
182
331
Chicago
Trying to maximize my storage length and was wondering. If the NVR is set up to record Constant, MD and IVS; does it record three separate streams or one main stream and bookmarks the events?
If each is separate streams, can I setup the continuous to record off the main stream at 10fps and the motion or IVS off of the sub-stream at 30fps?
Interested to know how others maximize their HD space.
With Dahua NVRs, the recorder creates a new file every hour. If there are no events, each file is an hour long. When an event occurs, the current file is closed and a new file created. When the event ends, the same thing happens. There are no markers, per se, just separate files. I record only main stream so can't answer for substreams, or for brands other than Dahua.
Reactions: looney2ns
