hello, i have a weird situation,
i installed 8 dahua cameras and 1 dahua nvr.
all the cameras are connected on one poe switch and the nvr directly to the router. the switch is also connected on router.
so i installed the first 7 cameras but the last one is denied to connect on nvr.
i can see the camera on nvr when i search for cameras, it has a green dot, when i add the camera, it has red dot and cannot connected. ( i triple checked password channels etc.)
i tried to ping the camera ( 192.168.1.108) from a pc connected on router, without success. if i connect a pc on same switch with the camera, it works and i can ping it. Also if i ping it from a device connected on wifi, it works i can ping it and access it.
i tried again 2 other cameras with default settings and they work fine, i can ping them on default ip 192.168.1.108 from everywhere. this specific camera cannot be accessed from a device on lan that is directly connected on router or any other switch.
Also i installed config tool, same thing i can see the camera but cannot access the configuration.
i went the camera on another facility and it works fine, the nvrs can see it and i can ping it from anywhere.
i reset the camera on defaults multiply times, also i tried many other ips whithout success
any idea whats can be wrong?
