bigredfish IPCT+ Member Sep 5, 2016 36,887 85,185 The Swamp Oct 27, 2024 #21 Is your IP static? If it changes, like most residential connections, and you didnt use DDNS, it will quit working everytime your provider issues a new IP Reactions: wezal15
M mat-with-one-t Getting the hang of it Mar 7, 2020 95 35 Melboure Oct 28, 2024 #22 Stuck at Step 2. Where do I find the file to send to my email? Thanks, Mat
wezal15 Getting the hang of it Jul 13, 2023 54 51 USA Oct 29, 2024 #23 mat-with-one-t said: Stuck at Step 2. Where do I find the file to send to my email? Thanks, Mat Click to expand... That is within your router settings. Go to Open VPN section and you’ll see something to export the file. Some images and info in this link will help. Sent from my iPhone using Tapatalk Reactions: SpacemanSpiff
M mat-with-one-t Getting the hang of it Mar 7, 2020 95 35 Melboure Oct 29, 2024 #24 Thanks! I’ll report back. Mat Reactions: wezal15
