hello everyone
im having a dahua 5 camera setup with 1 nvr
my setup is simple in wich all the wiring is comming from the camera to a network switch and from the switch a single wire to my router for all 5 camera
wheras the nvr is directly connected to the router via ethernet port
recently i have changed the carrier of my ISP and so i had the reconfiure the network on a whole in which i changed the main router web ui to 192.168.1.1 (PROVIDED BY THE ISP)
and my home netwrk to 192.168.2.1 for all my home traffic
so far i am having an issue in which when ever the automaintain feature rebbot my system one of hte camera ip changes and along with it nvr ip also change
i have set ip pool for camera excluding the camera ip set from the router
and set all the camera and nvr on static mannually assigned ip via the router and changed the ip in the cameras as well
however on every restart one of the camera and nvr chnage the ip address which is resulting in locking of that camera feed
any help is greatly appreciated
thankyou in advance
thankyou in advance
