Dahua NVR alarm output cycle on reboot/power-up
LouisG
Jun 6, 2019
15
51
NL
I would like to know if it's normal behavior that my Dahua NVR5432-4KS2 cycles all of the alarm outputs on reboot/power-up.
I have my NVR connected to a speaker system that plays an audio clip only when someone manually presses a button via the alarm outputs.
However, now and then the machine has to be rebooted and then it activates the alarm outputs automatically.
The speaker/audio is quite loud so obviously I don't want it to play when it's not absolutely necessary.
Is this normal? Can I disable this behavior?
