Hi
I've been searching around for ages and can't find anyone else that has had this issue. I'm new to IP cameras and have managed to finally access my DVR via internet explorer mode and the IP address. I understand you need to do this to access the full camera settings. I have two identical Dahua cameras up and one appears a slightly better image, and has a different 'quality' level on one of the settings, so I am assuming I need to access some more detailed settings, as I have no option to change it where I an see it.
To check I'm doing it correctly, my DVR has an IP address starting 192 which is consistent with my other devices, but the cameras have an IP address starting with 10. I initially thought I had to change this, but now I think that's how they are meant to be, please correct me if I'm wrong!
This issue now is shown in the images below which show the full height and width of my screen minus the URL bar at the top and taskbar at the bottom. I appear to be getting the block of images over the top of some options, and have been trying for hours to get them out of the way, they don't allow me to resize them or drag them across.
Does anyone know what I can do, could it be something to do with resolution? as the bottom picture shows the block disappears off to the right beyond the screen.
Many thanks...
Many thanks...
