Help! We run the rtsp from Dahua cameras through our custom built streaming server which turns the RTSP into HLS for display on all devices.
Has worked great for 2 years but now with the latest Dahua nvr and cameras we have ghosting / artifacts behind motion.
I notice that there is no setting for GOP / i-frame int. in the for the new Dahua cameras in the "encode" area.
It just automatically sets the GOP / I-Fram Int. to twice your FPS.
So if the FPS is set to 15 then it sets the GOP / Iframe int. to 30.
We would love to be able to control the GOP / Iframe Int. number.
Is there a way???
Anyone have any tips on this issue we are having?
When I lower the FPS it does help and the artifacts are less... but they are still there.
Please give any advice you think will help.
Thanks
Is there a way???
Thanks
