All,
I need guidance from people who use the External Local Alarm feature of their NVR.
My Dahua NVR 4216 has inputs for External Alarms. I have a laser line connected to Local Alarm Input #1. (sensor = Enforcer, twin photobeam detector)
It was working reliably for weeks. Now, it's acting up.
Setup:
The laser line is aimed across a driveway.
When the photobeam is broken (car, person), the sensor output changes. (the NC line is opened)
When the NVR sees an "event", it normally:
1) sends an "Alarm Start" email w/ timestamp
2) sends an email with snapshot
3) sends an "Alarm End" email w/ timestamp
Recently, the system has been misbehaving. For some events:
2) sends an "Alarm End" email w/ timestamp
ie: no snapshot is sent by the NVR.
My conclusions:
- This isn't a laser line detector problem. The laser line event is captured in:
a) the NVR system log and
b) the "Alarm Start" and "Alarm End" emails are sent.
- This is unrelated to the "anti-dither" alarm config setting in the NVR.
- This isn't caused by "too-frequent" or "too many" laser line events. The system could be sitting for hours, and when I drive up the driveway, no snapshot is sent.
My Hunch:
The "Alarm Start" and "Alarm End" can't be too close to each other.
ie: if "Alarm End" occurs before the NVR has a) gathered the snapshot, b) attached it to an email, and c) begun transmitting it the email, then d) the snapshot email isn't sent. Or it gets bumped by the "Alarm End" email.
Clue:
If I walk really fast through the laser line, it's more likely the snapshot won't be sent.
Again, this is a new symptom. The laser line setup used to be bullet-proof, even for short events (like running through the laser line)
Any ideas?
Thanks in advance!
Fastb
Setup:
My conclusions:
My Hunch:
Clue:
Any ideas?
Thanks in advance!
Fastb
