I’ve got several k42a’s I picked up from @EMPIRETECANDY and two of them have been working flawlessly for weeks.
I set up another two this past week and both have continuously fired WATCHDOG BI notifications 1-3 times an hour. It appears they are rebooting (light turns red like it does during start up).
They are running different firmware versions so it’s not that. I have Unmounted and plugged into my switch using different Ethernet cables that work with other cameras so I know it’s not the physical connection. I also tried a different switch so know it’s not that either. The camera’s settings match the other two working ones (Dahua settings and BI settings) so that shouldn’t be an issue. They are both powered by my POE switch.
Interestingly enough these two are both mounted 90 degrees sideways for a vertical picture. The two working ones are mounted vertically for the normal landscape view. This is the only difference in the firmware settings between these and the working ones. I’m going to set them to 0 degree rotation and see if that fixes anything (not sure why that would matter) but I wanted to post here and see if anyone else had this issue in the meantime.
Thanks!
Thanks!
