I'm trying to get my Dahua IPC-HFW1320S-W cameras to record to the nfs server which is running on my Raspberry Pi. The nfs server seems to be running OK. I followed the instructions at NASRecord - Dahua Wiki but nothing is being saved to the pi. Can I check that it should be possible for the cameras to record to the pi directly even when my PC is turned off? If not, is there another way to get recordings send directly to the pi?
Thanks
Thanks
