I had to run the cable between 2 studs so I had to cut the Network jack. Unfortunately my wife trashed it so I have no reference to wire a connector to the cable. Anybody knows the wiring scheme for proper poe?
Thanks
Thanks
Thanks
There are only solid colors no green...Orange-White, Orange, Green-White, Blue, Blue-White, Green, Brown-White, Brown
So that means you cut off the connector on the camera and not the cable feeding the camera. Unfortunately they use their own color scheme and it changes sometimes. I know this has been posted before.the camera has 6 wires:
gray
blue
yellow
orange
purple
brown
I think You need the pinout for the Dahua wires not the EIA/TIA stuff.
THIS WORKS.
