Dahua IPC-HDW3849H-AS-PV-ANZ-S2 Review
Greybubble
Jan 30, 2026
8
5
Australia
Been running a couple of these at a residential front door and a small shopfront entry. Writing this up because most threads on the 3849 are either spec dumps or "it's great" with no detail.1778570530809.png
Quick Specs
Resolution8 MP (3840×2160)
Lens2.8 mm fixed, F1.6, ~102° H-FOV
NightSmart Dual Illumination: IR + warm-white LED (both 30 m)
DeterrenceRed/blue strobe + white flood + 110 dB siren + 2-way audio
AISMD 4.0, AcuPick, tripwire/intrusion
Power802.3af PoE or 12 V DC
StoragePoE NVR + MicroSD up to 256 GB
IPIP67
What works well
Smart Dual Illumination does what it says. Default at night is IR. The moment SMD 4.0 classifies a human or vehicle, warm-white LEDs fire and you get a full-colour clip. Drops back to IR when the zone clears. So no constant white flood annoying the neighbours; colour only when something actually happens.
Active deterrence on confirmed SMD events: red/blue strobes + white floodlight + 110 dB siren + 2-way audio all hit simultaneously. You can also pre-load a voice message to auto-trigger — "You are being recorded, leave now" — fires without you touching your phone. More effective than it sounds.
AcuPick on a compatible AI NVR is legitimately useful — tap a detection thumbnail, it searches all channels for matching appearances. Saves a lot of manual scrubbing. Requires a Dahua AI NVR; SD-only standalone won't get this.
I wrote a longer version on our site if anyone wants to see
the full review of Dahua IPC-HDW3849H-AS-PV-ANZ-S2
Right camera for: front door, driveway, shopfront entry within ~6 m where active deterrence is the priority. Wrong camera for: LPR at range, covert install, Wi-Fi-only setup, long-boundary IR coverage.
Happy to answer questions on zone config or NVR pairing.
