- Jan 26, 2017
- 157
- 72
Hi all ,
Looking for a decent Dahua camera to record video and sound inside.
I need a good image quality and decent sound. I want to put a new security camera in my music room to keep an eye on all my gear.
The other reason I want good image and sound is for when the band is playing. We usually stick a video camera or Go Pro in a upper corner of the room. Video recording with sound is great when your working out new tunes and want to improve or see mistakes being made. It's also great for posting clips on the net to get feedback from your friends before you try performing it.
I figured why not using security footage to do this since I want to put a cam in the room for protection.
What advice and recommendations can you share ?
Thanks ,
Brian
Thanks ,
Brian
